Date/Time: Wed, 05 Mar 2025 04:28:02 +0000
SC with Tradovate & Jigsaw
View Count: 1674
[2022-01-17 06:04:02]
bdunn - Posts: 19
I am a bit confused as to what I might need to make this work. I am using Tradovate with Jigsaw and I will continue to use the Jigsaw DOM to place orders. I would like to have SC to use charts. Tradovate will only allow one connection to their data which is used by Jigsaw for MBO and ordering, so I believe I would like to get the Denali feed for realtime CME without MBO. I am looking at package 11 which I believe includes the real time Denali feed. Is there anything else I will need to do to make this happen or do I have it worked out already? I wanted to check before purchase. Would my total per month be $46 for package 11? Thanks.
[2022-01-17 16:34:10]
John - SC Support - Posts: 38380
You need to be aware that when getting data for the CME Group, you need to have a live, funded, futures trading account that we can connect to, in order to qualify for the non-professional exchange fees. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
In addition to not activating any exchanges for the Denali Exchange Data Feed, you also have not connected Sierra Chart to your trading account in order to meet this requirement. You will need to connect to your trading account at least once a month, and then you can set the service back to SC Data - All Services where it will not be connected. Refer to the following:
At Step #3 of the above, you need to connect to your trading account, which most likely will be a connection to CQG since you are using Tradovate. Refer to the instructions at the following link to connect to CQG:
CQG Trading Platform Service: Setup Instructions
