Date/Time: Wed, 05 Mar 2025 18:24:38 +0000
Scan a List of Futures to get Signal Insidebar in the quoteboard or Spreadsheet
View Count: 612
[2022-01-13 22:34:18]
User754379 - Posts: 13
Hi together,
at first - I am absolutly horrible in programming, but i am looking for a solution to scan a liste of Futures to get a alert/signal if there are a inside Day. Is it possible to create such scanner? is there anybody who have an idee how i could create that very easy. Or is there somebody out there who is able to do such silly thing very easy?
I need two conditions for the scanner.
1. after close of the day. Is there an insideday (insidebar studie) yes/no
2. Williams%R Indikator (Periode4) is the value <-25 or >-85
I am looking forward to here from you.
BR JOE
[2022-01-14 14:37:12]
John - SC Support - Posts: 38386
To do what you want, refer to the instructions at the following link to put together a watchlist with an Alert condition for scanning:
Study/Chart Alerts And Scanning: Scanning Large Number of Historical (Daily) Charts
In terms of the Alert condition that you would setup, it would look something like the following:
=AND(ID1.SG1, ID2.SG1 < -25, ID2.SG1 > -85)
Where ID1 is the Inside Bar study and ID2 is the Williams %R. You will need to change these for your particular setup.
Note that you specified that the Williams %R should be < -25 or > -85, but this gives a range of data between -25 and -85, hence the reason we did the Alert as an AND and not an OR.
