Date/Time: Wed, 05 Mar 2025 01:13:06 +0000
1min chart not working in replay mode
View Count: 894
[2022-01-11 16:45:38]
User386175 - Posts: 31
When using replay mode, the candles on the 1min chart do not show up. Is there a setting I have wrong? The other timeframes work.
[2022-01-11 18:24:48]
John - SC Support - Posts: 38380
The most likely issue is that you are starting the replay before the time where the 1 minute chart has data loaded.
How are you starting/running the replay?
Are you replaying multiple windows, or just one?
How are you defining the start time for the replay?
Do you have data in all the charts (particularly the 1 minute chart) going back to where you started the replay?
[2022-01-11 18:51:39]
-Im starting the replay mode using 'autotrade system replay backtest'
-im replaying multiple windows - 10 windows
-I select a date and time with the drop down 'accurate trading system backtest mode' then select 'play' then i select 'clear all trade data for symbol and account' then i enter '1' when it says 'enter processing steps in seconds'
-i think i have data to load in the charts, i didn't the only timeframe i have a problem with is the 1 minute.
[2022-01-11 18:56:29]
What is the start date of your replay?
What is the earliest date for data in your 1 minute chart?
[2022-01-11 19:22:08]
If I use todays date, I can get data on the 1 minute chart. I entered the date I was backtesting before, 5/12/2021 and I don't get 1minute chart data. I'm not sure how to check the earliest data for my 1 minute chart
[2022-01-11 21:26:23]
The easiest way to see the start date in your chart is to just scroll all the way to the left to the first bar and see what the date is for that bar.
Another option would be to open Chart >> Chart Settings and see how many days of data are loaded and work backwards.
It sounds like you are just starting your replay before where you have data in your 1 minute chart. The solution is either way for the replay to catch up to where the data starts, or to load enough data to go back to where you are starting your replay. Refer to the following for how to load more historical intraday data:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2022-01-12 20:52:38]
got it. its working now. i went to chart >> chart settings >> then added more days. thanks for your help
