Date/Time: Wed, 05 Mar 2025 19:38:14 +0000
Historical data missing
View Count: 615
[2022-01-11 01:19:53] |
User200064 - Posts: 31 |
Hello support, Out of nowhere I can't see historical data on my charts. It has been working correctly for many weeks but I just opened Sierra Chart to check the market and can't see historical, I can only see today's data starting at 18:00 New York time. I tried Edit > Delete all data and download but didn't work. I also tried restarting Sierra Chart and my computer but nothing. Any advise? Thanks |
[2022-01-11 07:34:52] |
We have put out a notice, that we have removed support for Sierra Chart provided historical data for Rithmic, unless you are using the Denali Exchange Data Feed. You are also using the old Rithmic connection. There are two things you need to do. First you need to update to the current version: Software Download: Fast Update And follow the instructions here: Rithmic Trading Platform Service: Setup Instructions And then you need to use to Denali Exchange Data Feed for complete and reliable market data for Sierra Chart when using Rithmic: Rithmic Trading Platform Service: Rithmic Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-11 12:58:13] |
I'm currently funded by a Trading Evaluator, the credentials they provided are through Rithmic. Can I use Denali as data feed and still trade my funded account?
[2022-01-11 14:39:40] |
Yes you can use the Denali Exchange Data Feed but there is the CME requirement that you have a standard live trading account. So in this case you need to follow this solution to obtain one to authorize the real-time data from CME: Easy Solution to CME Funded Trading Account Requirement Here is the full documentation: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-23 04:05:56] |
I already have an account with AMP, it is inactive so I would need to transfer funds to it. Should I go with AMP or should I open an account with Stage 5? I would like to have access to Teton, but I don't know if I can use Teton while trading with the account I received from the Trading Evaluator. I appreciate your help.
[2022-01-24 01:52:00] |
You can use your account at AMP and add 100 USD. In this case have them set you up on CQG and then just simply connect to that once a month: CQG Trading Platform Service: Setup Instructions Or I would like to have access to Teton, but I don't know if I can use Teton while trading with the account I received from the Trading Evaluator. Yes you can definitely do this. Just install two installations of Sierra Chart:Using Multiple Data and Trading Services at the Same Time Then you need to open an account with a broker supporting Teton. Not AMP. The list of brokers is at step 2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
