Date/Time: Tue, 04 Nov 2025 15:50:41 +0000
[Programming Help] - Trading DOM: Moving Stop to Break Even
View Count: 988
|   [2022-01-07 13:03:40]     |
| User963221 - Posts: 20 |
                Scenario:  I am in a trade using the DOM, I have an open long position, a 20 tick stop and no target order.  Price has moved in my favor say 4 ticks, I want to close the position before it moves against me.  (see attached screen shot where I captured this scenerio) Option 1: Drag my stop to current bid/ask and get filled (price may move many ticks while I get this done) Option 2: Hit Flatten (price may move and my fill may be bad) Option 3: Place a sell limit order (because I have attached orders turned on, I will end up with a DOM with other orders that have to be cancelled before they accidently get filled) Question 1: Is there a way to create a shortcut to move an order using a mouse click instead of click and drag on the DOM? Question 2: In my other platform there is an option to CANCEL all open orders when one order is filled, is this an option in Sierra Chart?  |
|   [2022-01-07 18:09:17]     |
| John - SC Support - Posts: 42754 |
                1. Yes, there are a few options for this including "Move Targets to Price" and "Move Attached Stops to Price". Refer to the information on setting up the "Trade Menu" at this link: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) 2. No, this does not exist inherently in the system, but you could create a trading program that would do this for you. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) And also refer to the following list of developers: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2023-09-29 15:57:45]     |
| j4ytr4der_ - Posts: 947 |
                I would very much like to use ACSIL to move all stops to a price, but haven't been able to figure out the function(s) to do so.  Any pointers on what to be looking at?
