Date/Time: Tue, 04 Mar 2025 21:23:27 +0000
confirmation about data access denied
View Count: 617
[2022-01-04 22:07:55]
User4576078808 - Posts: 7
Hi there,
Best wishes for 2022.
I am folowing a funding programm (with rithmic) and do not have access to intraday data.
This mention appears
"Download failed
Error downlading istorical intraday data for YMH2.CBOT. Historical data logon error: permission denied"
regarding this:
Easy Solution to CME Funded Trading Account Requirement and the screenshot It'a s appear thiat I need to open an account with stage r or AMP.
Can you please confirm that it is the real cause of my problem.
Best regards
Renaud
[2022-01-04 22:33:17]
John - SC Support - Posts: 38369
We do not know specifically what the problem is, but it sounds like you have one of the Account Names or Passwords incorrectly entered on the Data/Trade Service Settings for Rithmic.
We do recommend using our Denali Exchange Data Feed instead of the Rithmic data, in which case you would need to go through the setup as defined in the link you reference in order to have an account that will meet the CME Group requirements for the non-professional exchagne fees (the prop firms do not count towards this requirement).
If you decide to use the Denali Exchange Data Feed, then after you get your account setup with Stage 5 or AMP, then follow these instructions to setup the data feed:
