Date/Time: Tue, 04 Mar 2025 21:21:37 +0000
Can't see MBO on my DOM.
View Count: 1329
[2021-12-31 17:04:45]
EricMin - Posts: 2
Good Day,
I have Service Package 12 - Advanced MBO + Denali Data Feed and do not see the MBO's on my DOM. I have it added but no data?
Eric
[2021-12-31 18:23:48]
John - SC Support - Posts: 38369
Make sure you have gone through the Setup Instructions for the MBO data at the following link:
Market By Order Data: Step-by-Step Instructions
[2022-01-04 01:09:04]
EricMin - Posts: 2
Good Day,
I have looked over all the setting and I do not see the issue on my end. I have attached what I see...
Eric
attachmentEmail.docx - Attached On 2022-01-04 01:05:13 UTC - Size: 109.21 KB - 325 views
[2022-01-04 15:12:34]
The main issue is that you have not properly completed the Agreements for the CME Group data. You noted yourself as a Non-Professional, but you did not enter any information for your Broker/FCM, which is needed for the CME Group to consider you a Non-Professional.
If you are a professional, then we need for you to note that on the CME Non-Professional Certification.
You can access the agreements at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
Please let us know when you have completed these.
[2022-01-04 15:46:52]
Set your Minimum Market By Order Quantity to 0 in the symbol settings to ensure that you are getting the values. After doing this, disconnect from the data feed and reconnect (File >> Disconnect, File >> Connect to Data Feed).
If you still are not getting the MBO data for that symbol, then get us your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2022-01-04 15:47:11
