Date/Time: Tue, 04 Mar 2025 18:13:56 +0000
connection
View Count: 670
[2021-12-30 15:41:44]
User752442 - Posts: 36
i haven't been connected for a few hours
CQG/AMP issue?
[2021-12-30 16:17:34]
We would not know.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-12-30 16:26:15]
Software version: 2335 64-bit | 2021-12-30 17:24:02.022
Primary Thread ID: 14932 | 2021-12-30 17:24:02.022
Usage end date: 2022-06-11 | 2021-12-30 17:24:02.022
Enabled for: Advanced Features 2. | 2021-12-30 17:24:02.022
Enabled for: Sierra Chart Historical Data Service. | 2021-12-30 17:24:02.022
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-12-30 17:24:02.022
Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-30 17:24:02.022
Enabled for exchange2: CME | 2021-12-30 17:24:02.022
Enabled for exchange2: EUREX EOBI | 2021-12-30 17:24:02.023
Enabled for exchange2: fairx_exchange.data | 2021-12-30 17:24:02.023
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-30 17:24:02.023
Current selected Data/Trading service: CQG WebAPI | 2021-12-30 17:24:02.023
Custom symbol settings values: disabled | 2021-12-30 17:24:02.023
Chart Update Interval: 250 | 2021-12-30 17:24:02.023
Intraday Data Storage Time Unit: 0 | 2021-12-30 17:24:02.023
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-12-30 17:24:02.023
2021-12-30 16:24:02 Local computer time in UTC | 2021-12-30 17:24:02.023
2021-12-30 17:24:02 Local computer time in SC Time Zone | 2021-12-30 17:24:02.023
2021-12-30 15:51:58 Server time in UTC | 2021-12-30 17:24:02.023
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-12-30 17:24:02.023
Program path: C:\SierraChart\ | 2021-12-30 17:24:02.023
Data Files path: D:\Sierrachart\Data\ | 2021-12-30 17:24:02.023
OS Version Number: 10.0 | 2021-12-30 17:24:02.023
Locale Setting: C | 2021-12-30 17:24:02.023
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-12-30 17:24:02.023
Allowed protected custom studies: | 2021-12-30 17:24:02.023
CQG WebAPI | Connecting to server api.cqg.com | 2021-12-30 17:24:55.420
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-12-30 17:24:55.420
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-12-30 17:24:55.420
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-12-30 17:24:55.420
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2021-12-30 17:24:55.420
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. | 2021-12-30 17:25:16.459 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-12-30 17:25:16.460
CQG WebSocket | WebSocket closed. | 2021-12-30 17:25:16.460
CQG WebAPI | WebSocket closed. | 2021-12-30 17:25:16.460
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-12-30 17:25:16.460
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-30 17:25:16.460
CQG WebSocket socket (1) | Closed. | 2021-12-30 17:25:16.460
CQG WebSocket socket (0) | CloseSocket call. | 2021-12-30 17:25:16.475
CQG WebAPI | Disconnected. | 2021-12-30 17:25:16.475
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-30 17:25:16.475
CQG WebAPI | Connecting to server api.cqg.com | 2021-12-30 17:25:18.474
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-12-30 17:25:18.474
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-12-30 17:25:18.475
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-12-30 17:25:18.475
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2021-12-30 17:25:18.475
File >> Disconnect selected. | 2021-12-30 17:25:24.532
CQG WebSocket socket (1) | CloseSocket call. | 2021-12-30 17:25:24.532
CQG WebSocket | WebSocket closed. | 2021-12-30 17:25:24.532
CQG WebAPI | WebSocket closed. | 2021-12-30 17:25:24.532
CQG WebAPI | Disconnected. | 2021-12-30 17:25:24.532
CQG WebSocket socket (1) | Closed. | 2021-12-30 17:25:24.532
[2021-12-30 16:28:40]
after chat with AMP = CQG connection is okay
[2021-12-30 16:51:20]
price is updating on the right side now
but Candles stopped drawing ...
[2021-12-30 17:08:04]
after restart connection failed again
"Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-30 18:07:44.615
[2021-12-30 17:21:26]
You are experiencing a network connectivity issue or some issue on the CQG side with connectivity (Which would not be unusual in the case of CQG).
We cannot control this.
As an experiment, follow the instructions below and see if you have any connectivity issues. If not, this is a CQG issue. Let us know if you get connected following the below instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "Ok"
And then translate the symbols in your Chartbooks and Sierra Chart:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
Date Time Of Last Edit: 2021-12-30 17:23:24
[2021-12-30 17:34:48]
after win10 restart seems all to be okay now ... without experiment.
but good to know what to do in the future if problems occur
