Date/Time: Tue, 04 Mar 2025 15:04:36 +0000
Topstep setup
View Count: 805
[2021-12-20 15:17:41] |
alpmachine - Posts: 2 |
Hi guys Am i setup to be able to connect to rithmic and receive data? I am trying to set this up to work with topstep, but my Charts don't seem to be getting the data. Is there something else I need to do?
[2021-12-20 16:46:26] |
John - SC Support - Posts: 38341 |
You are setup to get the data from the Denali Exchange Data Feed, and everything looks good on our account, so you should not be having any issues. First, did you go through the Setup Instructions to connect to Rithmic? You will find these instructions here: Rithmic Trading Platform Service: Setup Instructions Second, after you connected to Rithmic, did you change your symbols to be the Rithmic symbols? If not, then be sure you select Edit >> Translate Symbols to Current Service. If you are still having an issue after doing the above, then get us a copy of your message log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
