Date/Time: Tue, 04 Mar 2025 14:56:29 +0000
Volume and Time and Sales issues
View Count: 643
[2021-12-19 16:36:36]
User989346 - Posts: 7
I'm using the trial version but getting 0 for "volume" on the "QuoteBook" and no information in "Time and Sales." I'm wondering if this is because it's Sunday morning? I'm not sure how I can practice or go forward if I can't see anything on the weekend. I should at least be able to see traded contracts from the previous day. I just see 0 for everything. NOTE: I tried manually entering the correct symbol as well as using "Translate Symbols to Current Service." Again, it seems to be partially working but 0 on volume still remains and "Time and Sales" are blank.
Private File
[2021-12-19 17:25:29]
Bet_More_Tim - Posts: 21
Hey bro, futures markets closed on the weekends lol.
Time and Sales data structure is only ever filled with live data, not historical. (at least it used to be that way, assuming it still is)
There is no liquidity to look at over the weekend, the only thing you'd be able to look at is a market depth historical graph if you have saved .depth files
if you would like to look at how things occurred chronologically through time, load a historical chart and add the studies.
For example, if you want to see "time and sales" , then load a 1tick chart, which means 1 chart bar per market order, and if you want to see a sort of "accumulated by price" time and sales, then load a 1price change chart, which only creates a new bar then the last traded price is different, and then add volume or whatever else you want to see.
I could be wrong, but I think volume profile type stuff is the main stuff not included in trial, that and potentially live data, but again, it's the weekend right now anyways.
[2021-12-19 20:20:46]
In regards to post #1 just tell us one of the symbols you are using.
[2021-12-19 21:57:40]
@Engineering Level: I'm not sure who I'm responding to, but in regards to your request, "Just tell us one of the symbols you are using," I've attached a screenshot already. But an example would be ZNZ21-CBOT. Note: I put in a request for direct messages.....still a bit confused on responding to the right person. Note: One user gave me a plausible answer, but I'm just following up with your request.
Date Time Of Last Edit: 2021-12-19 22:07:40
[2021-12-19 23:12:28]
The market is open now and you should start to see time and sales data.
Date Time Of Last Edit: 2021-12-19 23:12:36
