Date/Time: Tue, 04 Mar 2025 12:14:15 +0000
10 seconds data
View Count: 624
[2021-12-13 07:56:25]
User169228 - Posts: 1
Bar in 10 seconds are sometimes 5 seconds, sometimes 15 seconds, sometimes 30 seconds... Everything is false. (Fdax)
cpu 1%, no indicator, 32gb RAM. 270 Mb/s Gigabit internet, 1 single open chart
Can you explain to me why ?
Thank you
[2021-12-13 10:36:33]
Make sure both the main instance of Sierra Chart and all sub instances have a tick by tick data configuration:
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
If you still have an issue follow the instructions here:
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
We hope you are not using data from any other source other than Sierra Chart provided data. For example we hope you are not using Interactive Brokers data.
Date Time Of Last Edit: 2021-12-13 10:39:01
