Date/Time: Sun, 20 Sep 2026 09:43:55 +0000
2 Sierra instances & 2 data services
View Count: 1046
| [2021-12-06 06:25:58] |
| User5044343 - Posts: 68 |
Instance #1 is using "SC - Data - All Services" Instance #2 is using "DTC Service" I have my own DTC service socket streaming various data from other sources. What do I need to do or change in order to view one Symbol (ESZ21-CME specifically) in Instance #2 which would stream market data from Instance #1 - while still being connected to the DTC server. I tried setting "ESZ21-CME" in Symbol Settings - and sending it to the "DTC Protocol Server" that is enabled on Instance #1 but when loading "ESZ21-CME" in Instance #2 the request for data still goes to my custom DTC Service instead. |
| [2021-12-13 18:32:20] |
Follow the instructions here for this: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Although you will not be able to access the historical data using this method. That will be rejected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-13 20:52:56
