Date/Time: Tue, 04 Mar 2025 09:12:59 +0000
market depth requests not allowed on tradeing evaluator
View Count: 773
[2021-12-03 13:19:47]
User181801 - Posts: 42
Hello and thank you for your help.
In the trading evaluator mode (real-time not delayed) I am getting the following error "symbol is unknown. Click for symbol information. Makret depth is not allowed.
I have tried the fix: edit >> translate symbols to current setting but nothing changed.
Could you provide me with the next steps I should do, please?
Thank you,
Panos
imagesymbol unknown.PNG / V - Attached On 2021-12-03 13:18:23 UTC - Size: 4.22 KB - 151 views
imagetrading evaluator.PNG / V - Attached On 2021-12-03 13:18:32 UTC - Size: 11.47 KB - 167 views
[2021-12-03 16:32:26]
John - SC Support - Posts: 38341
What is the symbol for the chart for which you are getting this error?
[2021-12-05 19:13:07]
I happens with all the symbols I have up. MESZ21, MNQZ21, RTYZ21, CLF22, RBF22, 6EZ21, ZBH22, ZNH22
[2021-12-06 16:28:59]
You do not have any CME Group exchanges active on the Denali Exchange Data Feed. You can activate the exchange(s) you want for the CME Group from the following page:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
[2021-12-06 17:15:45]
Thank you, I had missed this step.
I am still having the same problem although I did activate the full CME with market depth package. I tried Edit >>> translate symbols to current service, but no change after restarting.
[2021-12-06 18:50:36]
Are you getting the same error message?
If so, then what is the exact symbol as it is entered in Chart Settings >> Symbol?
[2021-12-06 19:01:26]
Yes, I am getting the same error message, only if I choose the real time trading evaluator. In the delayed trading evaluator I do not get the error.
The error appears on all chart types and symbols, for example: ESZ21, NQZ21, CLF22, 6EZ21. DOM's, candlestick, tpo, etc.
I tried Edit >> Translate symbols for current service and also tried restarting many times.
Date Time Of Last Edit: 2021-12-06 19:18:12
[2021-12-06 19:28:40]
Do the following to get us your Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-12-06 19:36:51]
Thank you again for your time.
Software version: 2333 64-bit | 2021-12-06 19:33:52.114
Primary Thread ID: 10620 | 2021-12-06 19:33:52.114
Usage end date: 2022-01-10 | 2021-12-06 19:33:52.114
Enabled for: Advanced Features 2. | 2021-12-06 19:33:52.114
Enabled for: Sierra Chart Historical Data Service. | 2021-12-06 19:33:52.114
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-12-06 19:33:52.114
Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-06 19:33:52.114
Enabled for exchange2: CME (Trading Account Required) | 2021-12-06 19:33:52.114
Enabled for exchange2: CBOT (Trading Account Required) | 2021-12-06 19:33:52.114
Enabled for exchange2: COMEX (Trading Account Required) | 2021-12-06 19:33:52.114
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-12-06 19:33:52.114
Enabled for exchange2: fairx_exchange.data | 2021-12-06 19:33:52.114
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-06 19:33:52.114
Current selected Data/Trading service: Trading Evaluator | 2021-12-06 19:33:52.114
Custom symbol settings values: enabled | 2021-12-06 19:33:52.114
Chart Update Interval: 250 | 2021-12-06 19:33:52.114
Intraday Data Storage Time Unit: 0 | 2021-12-06 19:33:52.114
Time Zone: +00:00:00 (UTC+00) | 2021-12-06 19:33:52.114
2021-12-06 19:33:52 Local computer time in UTC | 2021-12-06 19:33:52.114
2021-12-06 19:33:52 Local computer time in SC Time Zone | 2021-12-06 19:33:52.114
2021-12-06 18:35:11 Server time in UTC | 2021-12-06 19:33:52.114
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-12-06 19:33:52.114
Program path: C:\SierraChart\ | 2021-12-06 19:33:52.114
Data Files path: C:\SierraChart\Data\ | 2021-12-06 19:33:52.114
OS Version Number: 10.0 | 2021-12-06 19:33:52.114
Locale Setting: C | 2021-12-06 19:33:52.114
DLLs: UserContributedStudies_64.dll | 2021-12-06 19:33:52.114
Allowed protected custom studies: | 2021-12-06 19:33:52.114
ESZ21-CME 1 Min #1 | Reloading chart. | 2021-12-06 19:34:21.717
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2021-12-06 19:34:31.198
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-06 19:34:31.198
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 19:34:31.198
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-12-06 19:34:31.198
Trading Evaluator | Network connection to server complete. | 2021-12-06 19:34:31.351
Trading Evaluator | Starting socket receive thread. | 2021-12-06 19:34:31.351
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2021-12-06 19:34:31.351
Trading Evaluator | Setting DTC encoding to Binary VLS | 2021-12-06 19:34:31.811
Trading Evaluator | Sending logon request message. | 2021-12-06 19:34:31.811
Trading Evaluator | Received logon response. | 2021-12-06 19:34:32.415
Trading Evaluator | Server Name: SC DTC Server. Build=40092. | 2021-12-06 19:34:32.415
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2021-12-06 19:34:32.415
Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2021-12-06 19:34:32.415
Trading Evaluator | Trading is supported. | 2021-12-06 19:34:32.415
Trading Evaluator | Order cancel and replace is supported. | 2021-12-06 19:34:32.415
Trading Evaluator | OCO Orders supported. | 2021-12-06 19:34:32.415
Trading Evaluator | Bracket Orders supported. | 2021-12-06 19:34:32.415
Trading Evaluator | Connected to server complete. | 2021-12-06 19:34:32.415
Triggering next historical data download in queue. | 2021-12-06 19:34:32.416
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-12-06 19:34:32.417
No download requests in the queue to start downloads for. | 2021-12-06 19:34:32.417
Trading Evaluator | Starting real-time market data updates for: ESZ21-CME. ID: 1 | 2021-12-06 19:34:32.460
Trading Evaluator | Requesting security definition data for: ESZ21-CME. ID: 1 | 2021-12-06 19:34:32.460
No historical data client is currently set to download historical Intraday data for ESZ21-CME. | 2021-12-06 19:34:32.460
Real-time Intraday chart data file updates started for ESZ21-CME | 2021-12-06 19:34:32.460
Intraday chart data file opened for ESZ21-CME | 2021-12-06 19:34:32.460
Symbol Error - ESZ21-CME is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2021-12-06 19:34:32.607
Trading Evaluator | Received security definition for symbol ESZ21-CME | 2021-12-06 19:34:32.630
DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-12-06 19:34:37.389
DTC Client socket (4) | Closed. | 2021-12-06 19:34:37.389
DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-12-06 19:34:37.389
DTC Client socket (5) | Closed. | 2021-12-06 19:34:37.389
DTC Client socket (4) | Deleting network socket now after delay. | 2021-12-06 19:35:07.403
DTC Client socket (5) | Deleting network socket now after delay. | 2021-12-06 19:35:07.403
[2021-12-06 22:47:21]
There are two problem occurring.
1. The symbols are incorrect. For the Trading Evaluator service, the symbol for the Z 2021 contract of the ES would be ESZ21. Make sure you have your chartbooks open and then select Edit >> Translate Symbols to Current Service.
2. You have signed up for the Non-Professional CME exchanges, which means that you need to connect to your live, funded futures trading account at the beginning of each month to qualify for the lower-priced exchange fees. You have not connected to your trading account yet this month. Refer to the following:
[2021-12-07 11:03:14]
Thank you for explaining, I am waiting for funds to go into my AMP account an will do that.
My symbols are now correct too. Have a good day. Your support is very good:)
[2021-12-07 17:24:50]
Thank you.
