Date/Time: Tue, 04 Mar 2025 06:38:53 +0000
F.US.EPZ21 not loading.
View Count: 759
[2021-12-02 15:14:03] |
User110225 - Posts: 23 |
Hi SC, I recently set up an account with AMP, funded the account and also set up my CQG connection. I now have the FULL CME group with market depth running, my account has been reviewed and accepted and I have also been given the CME-NON professional status with lower data fees. When I load up my ES charts its still delayed and it keeps giving me the error message: " Real time data feed subscription not enabled" I sent in my activity log as well. I got in contact with AMP and they say everything is fine on their side, my account is funded, verified and the balance is showing on Sierra Chart. They told me that I need to talk to the data feed provider/Sierra Chart about this. Can you please give me some advice on what to do here as I can not figure out what is going on. According to me everything should work. I was also assisted by my trader educator with the process and he advised me to get in contact with you. Regards https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=57656 |
[2021-12-02 17:11:43] |
John - SC Support - Posts: 38341 |
From your log, here is the problem: Allow Support for Sierra Chart Data Feeds is disabled.
Go to Global Settings >> Data/Trade Service Settings >> Common Settings and set Allow Support For Sierra Chart Data Feeds to Yes. Then select OK to close that window and then select File >> Disconnect followed by File >> Connect to Data Feed. After that you will be fine. Refer to the following for more information: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
