Date/Time: Tue, 04 Mar 2025 06:58:25 +0000
[User Discussion] - Sierrachart window/border color regedit setting Windows 10?
View Count: 593
[2021-12-01 21:43:41]
User725043 - Posts: 38
Sierrachart is setting the window, window title bar, and window border to the default Windows 10 settings for "Sub" windows.
Modified regedit for the "Main" window title bar, but have not been able to find the setting in regedit that Sierrachart is grabbing the color for the "Sub" window.
Please see the attached screenshot, where you can see the Main color set (dark grey) by regedit circled in red, but the Sub in AAPL chart still set at some default color circled in yellow.
Most settings of this type are in:
\HKEY_CURRENT_USER\Control Panel\Colors
Where in Windows 10 regedit is Sierrachart pulling the color for the Sub window, Sub window title bar, Sub window border?
imageCapture_sierra_bordercolor.PNG / V - Attached On 2021-12-01 21:37:42 UTC - Size: 13.64 KB - 179 views
[2021-12-01 22:19:54]
John - SC Support - Posts: 38341
On my system at least, it is using the default title bar color. I have no idea where Microsoft has that set.
But, if you go to Windows Settings >> Personalization >> Colors and scroll down you will see the list of Accent Colors. Underneath that is an option for Show Accent Color on the Following Surfaces: Title Bar and Window Borders. If you enable that option, then Sierra Chart will use that Accent Color.
[2021-12-02 02:46:24]
58LesPaul - Posts: 429
Now if we could get the border to change colors on whichever chart is selected in your chartbook that would be great!
