Date/Time: Tue, 04 Mar 2025 06:46:05 +0000
Order entry does not work
View Count: 429
[2021-12-01 15:05:43] |
timokrates - Posts: 28 |
Hi, I can not enter orders. On the sim it works fine, but if I switch to my AMP live account they simply do not show up when I click on the DOM. Funds are sufficent and I spoke with AMP. Margin or rejected orders are not the problem. I did not trade for some time and renewed service and Denali feed, has something to be (re-)activated? |
[2021-12-01 15:23:26] |
they simply do not show up when I click on the DOM. So you submit an order through the Trading DOM and then you do not see it there immediately afterwards?This would mean there must be a rejection and that would be in the Trade >> Trade Service Log. Or there was an order fill immediately. So you need to check the Trade Activity Log to see what the issue is: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-01 15:47:11] |
Just nothing happens after the click. But in the account panel I saw that the trading account (AMP / 118200) is not associated. Date Time Of Last Edit: 2021-12-01 15:47:50
[2021-12-01 16:36:08] |
John - SC Support - Posts: 38341 |
After you try to place the trade, go to Trade >> Trade Service Log and copy the information in that log and paste it into this thread for us to see what it states.
[2021-12-01 16:45:05] |
So sorry, I switched to sim on the trade window but did not switch trade simulation mode off. Sorry, did not use Sierra for a longer time. |
