Date/Time: Tue, 04 Mar 2025 07:22:03 +0000
Data
View Count: 564
[2021-11-30 22:24:33] |
User467352 - Posts: 1 |
I am only interested in the (ES) E-mini S&P 500 Futures. I'm not using Sierra Chart to trade because I trade on TD Ameritrade/TOS. I am only looking to use Sierra Chart to get the TPO/Market profile data for ES to see order flow and POC. To make sure I am understanding this correctly, I need to purchase Sierra Chart Advanced (package 5 at $36 per month) to get the Market profile info and then I need to also purchase CME Exchange #1 to get the real-time Denali feed at $31.20 per month?
[2021-11-30 23:16:33] |
John - SC Support - Posts: 38341 |
You would need the Advanced Package in order to use the TPO and Numbers Bars. If you are also wanting to get data from us, then you would need to be on Package 11 (Advanced + Denali Data Feed Fee). And you would need to activate whichever exchange meets your needs (such as #1 (Full CME Group with Market Depth for Non-Professionals)). Refer to the Setup Instructions for the Denali Exchange Data Feed for the CME Group data here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* But, you also need to be aware that in order to get data from the CME Group at the non-professional rate, you need to have a live, funded, futures trading account to which you can connect Sierra Chart at least once a month to perform the verification. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges We do not work with TD Ameritrade, so it is not possible to do the verification with them. Therefore, you would either need to pay the professional fees, or you could open an account with another firm to be able to do the verification - in which case, we recommend the following: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-30 23:17:15
