Date/Time: Wed, 16 Sep 2026 17:30:18 +0000
No data feed on personnal studies
View Count: 1051
| [2021-11-29 11:19:59] |
| User678021 - Posts: 4 |
Hello. On my personnal studies I don't have the data feed (it works otherwise). I have no data beyond 2021, february 26. Is there a way to fix this? Best regards, Jean-Yves JUSTE |
| [2021-11-29 15:50:52] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-29 16:23:57] |
http://www.sierrachart.com/image.php?Image=1638202973238.png
| [2021-11-29 16:48:36] |
Those are Rithmic symbols. Are you wanting to use Rithmic? Or do you want to use the delayed streaming EUREX data directly from Sierra Chart? All services are documented here: Supported Data and Trading Services: Supported Services For now, you will need to translate the symbols to the current service: Edit Menu: Edit >> Translate Symbols To Current Service (Edit >> Translate Symbols To Current Service) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-29 16:49:00
| [2021-11-29 17:31:40] |
OK thank you I translated and it works...but with a 15 min delay. I need the real time data. Where is the problem, knowing that I have the real time data on others charts?
| [2021-11-29 18:41:23] |
| John - SC Support - Posts: 47913 |
Our servers show that your Current Selected Service is set to SC Data - All Services. As such, you are only setup to get real-time data for CFD and Forex data. The CME and EUREX data would be streaming, but delayed by 10 to 15 minutes depending on the particular exchange. These are our standard offerings without any additional fees. So if you have charts that are real-time that are not CFD or Forex, then we do not know how that is possible. If you want real-time data, then we need to know the exchanges for which you want real-time data. This is necessary so we can ensure to give you the correct information and instructions as the CME Group, in particular, has special rules to be able to pay the non-professional exchange fees - for further information on this topic, refer the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-29 19:07:27] |
Do you have an account with Rithmic?
| [2021-12-29 22:35:14] |
Hello. No, I don't have a account with Rithmic. I have updated my current service package to 11, but I still have a 15 min delay for some studies. I need real time data for futures on DAX40, SP 500 and DJ30. Do I have the good package for this? |
| [2021-12-30 17:59:23] |
You have the correct Service Package. For information about real-time futures data, refer to: Is Historical and Real-time Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
