Date/Time: Tue, 04 Mar 2025 04:20:48 +0000
Hi, mostly a datafeed issue...
View Count: 630
[2021-11-24 19:04:13] |
moneylovesdwayne - Posts: 5 |
Happy Holidays :) My first time setting up OIL and Energy charts in Sierra. I have the CQG, Denali, Sierra platform setup. According to my understanding, I am paying for NYMEX thru Sierra/Denali. The data loads to the .cht template i was provided by trade pro academy, but there's no real time feed... (some charts throw the not found error) I just checked with AMP, I am set up correctly. I'm trying to load NYMEX products for the first time, and despite doing it manually and via rollover etc from a January template, I keep getting symbol not found. I've tried CLEF22 and F.US.CLEZ21... misc... what's the best way to align the charts so that you don't have to scroll to ensure one is at the current price and centered? if I screw up a chart and don't want to start over (without a save), how do I go back to it's happy state? thx Dwayne |
[2021-11-24 19:13:42] |
John - SC Support - Posts: 38341 |
The first thing we want you to do is to open the Chartbook you are wanting to work with and select Edit >> Translate Symbols to Current Service. This will update the symbols that were set for each chart to the service you have selected (sounds like CQG in your case). Let us know if that resolves your issue or not. With regards to the chart messing up, the easiest thing is to simply not save it. Then close the Chartbook (again, do not save) and then you can re-open the Chartbook and it will be in the state from the last save. There are also Backups made from each time you start Sierra Chart that you can access. Refer to the following: Chartbooks (Workspaces): Accessing a Backup Chartbook File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-24 20:03:05] |
hi again, I have tried that method a few unsuccessful times... Most of the charts have data, broken looking, but no feed. I tried F.US.CLEZ21 and F22 to no avail... thanks on the backups info, I may leverage that someday, but I'd still like your help in striking oil plz :) Date Time Of Last Edit: 2021-11-24 20:03:42
[2021-11-24 20:52:53] |
According to my understanding, I am paying for NYMEX thru Sierra/Denali. No this is not the case. You need to activate the NYMEX exchange from here:https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed And it sounds like you want to use a Constant Range Scale: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Chart Scale and Scale Adjusting: Scale Range (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
