Date/Time: Mon, 03 Mar 2025 22:15:13 +0000
Numbers Bar Auto Resize
View Count: 697
[2021-11-17 17:36:12] |
Matador Trader - Posts: 24 |
Is there a way for numbers bars to automatically resize when price moves fast. Right now I have to manually control click the axis every few minutes to be able to actually see the numbers. In the distant past I used a chart from GoMindicators and it had that functionality so I was just wondering if I could do it natively with sierra chart. Thanks! |
[2021-11-17 18:14:01] |
John - SC Support - Posts: 38341 |
We are not sure exactly the situation you are encountering or what resizing you want to occur. If your chart is set to Automatic scaling, then any new bars are going to be kept within view as they are added to the screen. If you do not want the automatic scaling, then you could use a Constant Range chart with the option to Keep the Last Bar within View. Refer to the following: Chart Scale and Scale Adjusting: Constant Range (Scale Range) And then there is the automatic font sizing option for the Numbers Bars itself. Refer to the following: Numbers Bars: Font Size Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
