Date/Time: Mon, 03 Mar 2025 22:01:51 +0000
Trading
View Count: 550
[2021-11-12 01:13:26] |
User403758 - Posts: 25 |
Hello. I bought service pacckage 11 and booked CME and EUREX realtime data via SC. So the data are good and working fine now. My Broker is AMP .with CQG realtime data. Now I dont need CQG realtime anymore and want to cancel this. My question is, how can I now trade (routing Orders to AMP). IF I select in SC the SC data (File > ...) I can only trade im simulation. But if I select AMP CQG Webtrading, then I cannot use SC data, only CGQ. So how to use SC data service WITH routing Orders to AMP. Very important, thanks! Date Time Of Last Edit: 2021-11-12 17:33:53
[2021-11-12 21:11:39] |
John - SC Support - Posts: 38341 |
Sierra Chart is built to allow you to get the data from us and trade with your desired trading service. Therefore, you will setup your system to connect to CQG by following the instructions at the following link (if you have not already done so): CQG Trading Platform Service: Setup Instructions Then you would go through the instructions at the following link to make sure everything is setup properly to get the Denali Exchange Data Feed Data: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
