Date/Time: Mon, 03 Mar 2025 18:14:33 +0000
YM Daily Chart
View Count: 456
[2021-11-11 15:17:02] |
User417302 - Posts: 67 |
I am trying to create a daily chart for YM. However, it is missing data from April thru September. I have tried to delete the data and redownload, but that is not working and it keeps giving me the same missing data. How can I fix this? Thanks, |
[2021-11-11 16:34:50] |
John - SC Support - Posts: 38330 |
First, make sure that you are using a Continuous Futures Contract. Refer to the following: Continuous Futures Contract Charts Second, if you are setup for a Continuous Futures Contract, be sure you select Edit >> Delete All Data and Download and then you should get a window that asks you which contracts you actually want to reload the data for. Be sure you select the contracts that cover the period for which you are missing data. Refer to the following: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
