Date/Time: Tue, 26 Nov 2024 02:45:56 +0000
QQQ CFD by Interactive Brokers
View Count: 1825
[2014-03-31 19:43:41]
User79031 - Posts: 2
Good evening,
I need advice how I enter into the sierra chart (find symbol), the market QQQ "NASDAQ.NMS CFD / POWERSHARES QQQ TRUST SERIES" (Interactive Brokers). I tried to enter the QQQ-CFD-SMART-USD-BAAVG, but the market was not running. When I entered the ticker QQQ-S-SMART and market ran, but when I tried to execute a trade, nothing happened. I had to trade QQQ directly from TWS from Interactive Brokers, and it is quite uncomfortable. If I trade the market NQ-201406-GLOBEX and everything works well. What I have to do to be able to trade the market QQQ on the platform sierra chart and as a broker use Interactive Brokers.
Thanks for the answer.
Yours sincerely,
Jan Cisar
Login: sierrajan
[2014-04-01 09:30:10]
When you try to execute a trade were there any error messages given in Trade >> Trade Service Log for that symbol.
Based upon what you are describing, really we do not know how much we can help with this. Really Interactive Brokers would be able to help you the best.
[2014-04-01 09:41:16]
What we are trying to say, is that when you submit an order from Sierra Chart and there is some problem with it, then Trader Workstation usually will respond with an error in Sierra Chart will list this in Trade >> Trade Service Log.
If there is no response from Trader Workstation, we have almost no idea what the problem would be . You really would have to rely upon Interactive Brokers support for that.
[2014-04-01 09:44:55]
QQQ-CFD-SMART-USD-BAAVG is generally the correct format.
The only other thing we would suggest is to change SMART to the actual exchange code that Trader Workstation specifies for this market.
