Date/Time: Mon, 03 Mar 2025 10:52:49 +0000
Skip historical data download for options from Interactive Brokers
View Count: 457
[2021-11-03 20:19:11] |
WheresMoney - Posts: 62 |
When I create a DOM (which I understand internally is just a chart) for options, Sierra is downloading historical data for the option which I don't need and uses up a lot of time. Is there a way to stop all backfill download for options?
[2021-11-03 23:36:55] |
John - SC Support - Posts: 38292 |
There is not a way to do this and have it just for Options. But, there is a way that you can do this for a Trading DOM in general. To do this, enable the option for Chart >> Chart Settings >> Disable Data File Updating and then enter the same symbol name in the Chart >> Chart Settings >> Trade and Current Quote Symbol. This way, you will get the quote updates but not the trade data. Just keep in mind that doing this means that you will not be able to add any studies to that Trading DOM, as they are dependent on the underlying trade data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
