Date/Time: Sun, 02 Mar 2025 21:32:39 +0000
Number Bars - Historical Pullback Color(Based on +/-)
View Count: 1263
[2021-10-27 23:19:19]
User866150 - Posts: 14
I am writing to suggest an option for Historical Pullback delta be allowed color changes via "Based on +/-"
Similar to Subgraphs
Not seeing this anywhere in the options/board, it would be a nice addition
[2021-10-28 00:28:09]
John - SC Support - Posts: 38292
What you are asking for can already be done in the Numbers Bars for the Pullback column when displaying the text as Ask Vol Bid Vol Difference.
In this case, just set the Pullback Column x Text Coloring Method to Based on Ask Vol Bid Vol Difference - Actual in which case positive numbers will use the Up colors and negative numbers will use the Down colors. Refer to the information at the following link for this coloring option:
Numbers Bars: Text Coloring Based on AskVol BidVol Difference - Actual
Also be aware of the option to use different colors for text coloring:
Numbers Bars: Use Separate Colors for Text Coloring Method
If you are looking for something else, then give us some additional information on what you are looking for, as we obviously did not understand.
[2021-10-28 02:55:44]
Thanks for your reply.
I am using it in this way, but this post is referencing the top/bottom delta values of Historical Pullback Difference. This is NOT a column. Specifically, it's the numbers at the TOP/BOTTOM of the bar (SS attached for clarification - highlighted in yellow, including the MENU option selected to achieve this measure).
This text color can only be changed via "Default Text Color" - but I would like to color based on +/- value.
I tried your suggestion and the text is still based on Default color, which I assumed as it's not a column...
Would also like to add on this suggestions - allow the "Historical High/Low Pullback Color" to be transparent. Currently you are only allowed a boxed layer behind the numbers.
The only workaround is changing it to the same background color - but you still have a solid box that covers up other data/signals.
imageHistorical Pullback NUMBERS.PNG / V - Attached On 2021-10-28 02:50:52 UTC - Size: 2.35 KB - 272 views
imageHistorical Pullback MENU.PNG / V - Attached On 2021-10-28 02:50:56 UTC - Size: 2.32 KB - 223 views
[2021-10-28 13:59:29]
The only controls for that particular Pullback item is what is on the Inputs for the Numbers Bars study. So this would be a Feature Request to add these items.
[2021-10-28 17:45:03]
Yes, I would like to suggest an option for Historical Pullback delta be allowed color changes via "Based on +/-"
You guys are awesome,
Thanks!
