Date/Time: Fri, 11 Sep 2026 20:12:02 +0000
Delayed Data
View Count: 1112
| [2021-10-19 15:09:55] |
| User925260 - Posts: 30 |
Hello It has been over a week since I renewed my services and I still have delayed data. I currently have AMP futures for my trading account and does not show my balance or order in sierra charts either. Please fix data issues and connect my account to AMP. Thanks |
| [2021-10-19 17:25:41] |
| John - SC Support - Posts: 47853 |
Everything in your account looks good. We want to point out that the only exchange you have active is the "CBOT with Market Depth", so you will only get real-time data for symbols on that exchange. If still have a problem, then we would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-21 15:10:45] |
File attached
| [2021-10-21 15:16:35] |
There is the following in your log: Sierra Chart account data changed. Requesting updated account information.
We need for you to exit from Sierra Chart and then use the Forced Login option for when you start Sierra Chart again. Refer to the following information for how to use Forced Login: Sierra Chart - Software Login Instructions: Forced Login After that, get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-21 15:49:30] |
Did the forced login and then message log saved file
Private File |
| [2021-10-21 17:37:29] |
The log looks good. You should be getting your data properly now. If you are having an issue, please let us know.
| [2021-10-22 13:57:51] |
hello data is still delayed, it has been over two week i have paid over $70 for delayed data that is not real time/accurate. Please enable real time services and credit two weeks of delayed data |
| [2021-10-22 15:03:06] |
Tell us what symbol is delayed. The difficulty is with CME market data rules not us. It is the exchange, which creates monumental monumental monumental frustration for everyone regarding real-time data access. They are to blame. 1000%. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-22 15:04:54
| [2021-10-22 15:23:07] |
We see a lot of symbols like this in the log you submitted previously: MGCM21-COMEX This is on the COMEX and you will not receive real-time data for this symbol. You need to activate that exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed You do have real-time data now for the CBOT. So you have not been paying for COMEX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-25 14:10:06] |
Hello, I only actiavted Comex orderbook data services which is what I always subscribe to, please change services to real time comex. |
| [2021-10-25 14:21:02] |
Do you require market depth data for COMEX?
| [2021-10-25 14:31:15] |
yes please
| [2021-10-25 14:44:46] |
Could you please add 10 USD to your account here to cover the cost of the exchange fee: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Let us know when this is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-25 14:50:10
