Date/Time: Tue, 04 Nov 2025 14:57:38 +0000
[User Discussion] - Swing Line question
View Count: 3247
|   [2013-03-22 12:34:14]     |
| Avio - Posts: 14 |
                I’m trying to plot the Clear Method Swing Line as a ribbon in region 2 and I’m able to do it. I would like to go one step farther and be able to distinguish when the line is up/down and when is flat by using different colors. I tried it with no success. Is that possible and if so how? What do you write when let say you have 5-7 bars in a row with the same value for the swing line? Thanks.  |
|   [2013-03-23 02:45:18]     |
| M5amhan - Posts: 468 |
                it looks like it already colors automatically when moving up and down http://www.sierrachart.com/image.php?l=1364006708531.png im sure someone here knows how to write a simple alert code to do this, try searching this forum and the old forum for this code  |
