Date/Time: Sat, 01 Mar 2025 17:01:20 +0000
Daily pivot points S4.5 & R4.5 are missing on my charts
View Count: 600
[2021-10-12 15:53:11]
User50927 - Posts: 91
On both the Pivot Points-Variable Period and the Pivot Points-Daily (default parameters) studies I can't get the S4.5 & R4.5 levels (bottom of the table)to plot after I activate them. Everything else seems to be in working order, including the 3.5 levels.
[2021-10-12 17:51:09]
John - SC Support - Posts: 38292
Make sure that the chosen Pivot Points calculation includes S4.5 and R4.5. Refer to the information here:
Pivot Points: Formula Types
[2021-10-12 20:30:05]
What's weird is that using the default formula type, "0", the study plots levels 1.5, 2.5, and 3.5 even though it's not supposed to - according to the calculations you referenced above. And they look right too!
Maybe someone should double-check that part of the code at some point, but please don't take the existing 0.5 levels off if you can help it, although you might have to for the sake of correctness/accuracy, in which case adding an extra formula "0" + half levels to the list might be a better option. Thanks.
[2021-10-13 00:16:01]
Our apologies, we try to keep our documentation up to date, but somehow this got missed.
You are correct, there are Pivot Points for Calculation Mode 0 at the 0.5, 1.5, 2.5, and 3.5 levels, which are just the average of the levels above and below.
Note that there is NOT a level 4.5, so that is why you are not seeing it.
We will update the documentation to reflect these other levels for that calculation mode.
Date Time Of Last Edit: 2021-10-13 00:17:18
