Date/Time: Tue, 04 Nov 2025 13:48:51 +0000
Threading model
View Count: 1275
|   [2021-10-04 10:22:58]     |
| backinblack - Posts: 41 |
                Hi, What is the threading model SC follows to: 1 - Execute all the studies in a single chart 2 - Does 2 charts in the same chartbook have their own thread of execution? 3 - what happens in case of multiple chartbooks opened simultaneously? Do each chartbook have their own separate thread of execution? I am planning to run a handful of custom studies along with standard SC studies for multiple markets with automatic trade execution. Each market in its own chartbook. Am looking to deploy them on a few machines. This would help me identify if i need machines with more cores but average cpu speed per core or machines with less cores but high cpu speeds per core. In terms of memory, i never noticed SC taking a very high amount of RAM. But ofc that is a factor of how much data are you loading. Thanks J  |
|   [2021-10-04 18:04:47]     |
                There is only one thread used for study calculations. If you want to use multiple threads you need to use additional instances of Sierra Chart: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-10-04 22:50:07]     |
                Thanks. Does this mean that there is a single thread per SC instance, for studies across all the chartbooks running as a part of that instance?
|   [2021-10-05 12:36:37]     |
| Sierra_Chart Engineering - Posts: 21299 |
                Yes.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
