Date/Time: Sat, 01 Mar 2025 11:11:23 +0000
VIX Index: Which data feed and exchange
View Count: 562
[2021-10-01 16:41:44] |
tobi - Posts: 351 |
Which data feed and exchange needed to get realtime data of the VIX Index? There are conflicting information: VIX Index part of Denali + CFE Upcoming Data Feed Plans 2, New Exchange | Post: 267679 VIX Index available with Sierra Chart Exchange Data Feed + CBOE Indices Denali feed | Post: 278170 Date Time Of Last Edit: 2021-10-01 16:43:23
[2021-10-03 18:59:52] |
John - SC Support - Posts: 38292 |
It's not conflicting information, it is just similarly named items by the same company. So we need to know, which VIX are you wanting to get data for. Do you want the actual VIX Index, which is provided by the CBOE or are you wanting the VIX Futures, which are traded on the CFE (CBOE Futures Exchange)? The VIX Index is part of our Sierra Chart Exchange Data Feed. You will find the information you need and Setup Instructions here: Sierra Chart Exchange Data Feed The VIX Futures (CFE) are part of the Denali Exchange Data Feed. You will find the information you need and Setup Instructions here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
