Date/Time: Sat, 01 Mar 2025 01:47:18 +0000
Default DOM Order is to many contracts
View Count: 552
[2021-09-13 21:02:53]
Kylek1485 - Posts: 6
Somehow I have gotten my DOM to default to 25 contracts when I'm buying or selling. I do not know how I made this change. I used to click or buy or sell and it would be 1 contract default, but now its 25. How do you change this?
[2021-09-13 23:06:32]
John - SC Support - Posts: 38292
There are a number of ways to change the quantity for your orders. The easiest is to open the Trade Window for that chart. To do this, ensure that the chart that has the issue is the active chart, then select Trade >> Open Trade Window for Chart. On that window, change the quantity to what you want it to be. Whatever the quantity is set to when you save the Chartbook is what it will be when you go to place your orders. Refer to the following:
Basic Trading and the Trade Window: Main >> Order Quantity (Quantity)
Just keep in mind that if you are using Trade Configurations, then those will change the quantity based on what is saved in the Trade Configuration. Refer to the following:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
