Date/Time: Fri, 28 Feb 2025 13:24:12 +0000
Sierra Update and Rithmic Data Feed
View Count: 660
[2021-08-23 13:58:52] |
Pasco27 - Posts: 10 |
Hello -- SC updated this weekend and I've lost connection with Rithmic data feed. Been attempting to restart it, break connection / reconnect, and even revert SC revisions. Nothing working so far- can you help?
[2021-08-23 15:53:30] |
Kza57 - Posts: 13 |
Same problem for me but with the Rithmic direct DTC. Unable to connect Rithmic direct DTC with 2299 Only work with 2293 |
[2021-08-23 16:26:51] |
Thank you! Hopefully they get it figured out soon.
[2021-08-23 18:42:00] |
John - SC Support - Posts: 38259 |
If you are still having an issue when using the Rithmic Direct - DTC connection, please let us know.
[2021-08-23 18:49:57] |
Yes, still having trouble since the SC update this weekend. It was working last week.
[2021-08-23 19:10:26] |
Get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-23 19:12:09] |
We have already contacted Rithmic about this. We do not know what the issue is at this point in time. We do not need to see the Message Log.
[2021-08-23 19:33:20] |
Attached.
[2021-08-23 20:12:00] |
As noted, this is a Rithmic issue and they have been notified.
[2021-08-26 17:02:58] |
This has been resolved by Rithmic as we understand.
