Date/Time: Fri, 18 Sep 2026 09:14:15 +0000
Limited data showing on intraday chart
View Count: 958
[2021-08-19 23:02:42]
User923944 - Posts: 8
I have opened a new intraday chart (ES) and find that it will only show me bars from the time the chart was opened even though my chart settings call for 30 days of data and selects a date range beginning several months back. I have tried "delete all data and download", but same result. If it makes a difference, I'm using a rithmic connection with credentials supplied by Edgeclear. Can you make a suggestion? Thanks
[2021-08-20 03:07:20]
We need to get some information from the Message Log. First thing we want you to do is to follow the instructions here to update to the latest prerelease (2298):
After the update follow the instructions below.
Reconnect to the data feed:
[2021-08-21 21:13:11]
Software version: 2299 64-bit | 2021-08-21 15:07:47.891
Primary Thread ID: 4192 | 2021-08-21 15:07:47.891
Usage end date: 2021-09-14 | 2021-08-21 15:07:47.891
Enabled for: Advanced Features 2. | 2021-08-21 15:07:47.891
Enabled for: Sierra Chart Historical Data Service. | 2021-08-21 15:07:47.891
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-21 15:07:47.891
Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-21 15:07:47.891
Enabled for exchange2: CME | 2021-08-21 15:07:47.891
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-21 15:07:47.891
Current selected Data/Trading service: Rithmic Direct - DTC | 2021-08-21 15:07:47.891
Custom symbol settings values: enabled | 2021-08-21 15:07:47.891
Chart Update Interval: 500 | 2021-08-21 15:07:47.891
Intraday Data Storage Time Unit: 1 | 2021-08-21 15:07:47.891
Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-08-21 15:07:47.891
2021-08-21 21:07:47 Local computer time in UTC | 2021-08-21 15:07:47.891
2021-08-21 15:07:47 Local computer time in SC Time Zone | 2021-08-21 15:07:47.891
2021-08-21 21:05:55 Server time in UTC | 2021-08-21 15:07:47.891
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-08-21 15:07:47.891
Program path: C:\SierraChart\ | 2021-08-21 15:07:47.891
Data Files path: C:\SierraChart\Data\ | 2021-08-21 15:07:47.891
OS Version Number: 10.0 | 2021-08-21 15:07:47.891
Locale Setting: C | 2021-08-21 15:07:47.891
DLLs: UserContributedStudies_64.dll | 2021-08-21 15:07:47.892
Allowed protected custom studies: | 2021-08-21 15:07:47.892
File >> Disconnect selected. | 2021-08-21 15:08:50.183
WSACleanup called. | 2021-08-21 15:08:50.183
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-08-21 15:08:50.184
DTC Client socket (1) | CloseSocket call. | 2021-08-21 15:08:50.185
Rithmic Direct - DTC | Disconnected. | 2021-08-21 15:08:50.185
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-08-21 15:08:50.185
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-08-21 15:08:50.223
DTC Client socket (1) | Closed. | 2021-08-21 15:08:50.224
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-08-21 15:08:58.089
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-08-21 15:08:58.092
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-08-21 15:08:58.092
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-08-21 15:08:58.093
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-08-21 15:08:58.093
Rithmic Direct - DTC | Network connection to server complete. | 2021-08-21 15:08:58.137
Rithmic Direct - DTC | Starting socket receive thread. | 2021-08-21 15:08:58.137
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-08-21 15:08:58.137
Rithmic Direct - DTC | Sending logon request message. | 2021-08-21 15:08:58.137
Rithmic Direct - DTC | Received logon response. | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Server Name: . | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Successfully connected. | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Trading is supported. | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | OCO Orders supported. | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-08-21 15:08:58.288
Rithmic Direct - DTC | Connected to server complete. | 2021-08-21 15:08:58.288
Triggering next historical data download in queue. | 2021-08-21 15:08:58.290
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-08-21 15:08:58.291
No download requests in the queue to start downloads for. | 2021-08-21 15:08:58.291
[2021-08-23 21:46:41]
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges)
[2021-08-23 22:09:05]
My broker is Edgeclear. Using the rithmic credentials they supplied, I am able to open an ES intraday chart, but only five days of data is provided. At this point, I'm inclined to switch to the Denali exchange data feed with Sierra chart order routing to Edgeclear. Would that be your suggestion?
[2021-08-24 14:49:10]
Well you do already have the Denali Exchange Data Feed active. The next step is to make sure you are connecting to your live Rithmic account. Instructions:
Rithmic Trading Platform Service: Setup Instructions
When our direct CME order routing becomes available through Edge Clear we would recommend switching at that time, to that service.
