Date/Time: Fri, 28 Feb 2025 13:33:58 +0000
Unable to left click P&L column on a DOM
View Count: 517
[2021-08-19 12:36:58]
MR17 - Posts: 34
hi !
i wish to change the P&L format on my DOM but for some reason, nothing changes whenever i left click on the head column !!
i even close everything and reopen but the issue still holds
is there another way to change that format ?
thanx
[2021-08-19 15:38:23]
John - SC Support - Posts: 38259
What you are trying to do is the right way to change what is displayed. There really should not be any issue with this.
Just to ensure, you have the Profit and Loss column displayed in your DOM, and you have the header that states "P&L" showing at the top of the column. You then have an open position, such that there is a Profit and Loss being calculated for that position. Then you are left-clicking on the letters "P&L" to change the format.
What does the display of the Profit and Loss show?
[2021-08-19 15:59:15]
MR17 - Posts: 34
actually i just understood that i do have to click on the column to change format but only when there is an open position ! otherwise it does not work but i did not get that little details !!
so thanx
imageP&L issue.png / V - Attached On 2021-08-19 15:56:14 UTC - Size: 279.4 KB - 167 views
