Date/Time: Mon, 25 Nov 2024 17:48:39 +0000
Scroll all Charts to End
View Count: 844
[2021-08-12 06:50:38]
nicktrader - Posts: 710
I use both detached and attached charts (two different chartbooks). The command "Scroll all Charts to End" works for the "detached" charts only, but not for the "attached" ones.
I use a second PC with the same chartbooks and there both variants work.
Many thanks
[2021-08-12 13:53:34]
John - SC Support - Posts: 36255
When we try this, we are not able to reproduce it.
Can you please attach the chartbooks to this thread so we can see if we can reproduce it with your chartbooks.
What version of the software are you running?
How are you selecting the option "Scroll All Charts to End"? Are you doing it from the Menu or do you have a Keyboard Shortcut or Control Bar setup for it?
If you are using a Keyboard Shortcut or Control Bar, then we would also want to get your Sierra4.config file which will be in your main Sierra Chart installation folder (typically C:\SierraChart).
[2021-08-12 18:19:10]
- Ver.: 2296
- menu
Private File
[2021-08-12 18:54:26]
The reason you are having the problem is that in one chartbook you do not have any attached charts. Therefore, when you select the pulldown for Chart >> Scroll All Charts to End, you are activating the main screen and creating a situation where you do not have any charts active, which in turn makes it so that the system does not recognize any charts to scroll to the end.
In this situation, if you were to take one of the Detached charts and turn on the menu and select Chart >> Scroll All Charts to End, they will all scroll to the end.
Another solution would be to just have one window attached to the main window, which would then become the active chart when you select the pulldown option in the main window.
[2021-08-12 20:19:05]
John, I do understand the "dilemma."
The "default" focus is on the "detached" chartbook because these charts do not have the status "Window always Visible". If I want to execute the command "Scroll All Charts to End" in one of the "attached" chartbook chart , I also have to set the focus on this chartbook.
Many thanks
