Date/Time: Fri, 28 Feb 2025 09:11:00 +0000
Data issue on TPO chart
View Count: 468
[2021-08-10 23:15:48]
User789550 - Posts: 17
I had to delete a bunch of the saved data as my computer was low on space, when I re downloaded ES data my TPO chart has an issue. On AUG 5 it shows price went down to zero. My vol profile is not happy.
Sorry if this is an easy fix, just don't know how to change it.
Attached is a photo
Thanks in advance
imageScreenshot from 2021-08-10 07-53-18.png / V - Attached On 2021-08-10 23:08:45 UTC - Size: 119.91 KB - 159 views
[2021-08-11 13:56:00]
John - SC Support - Posts: 38259
Do you have any other studies on that chart? Our first guess is that it is another study that is going to zero and causing the entire chart to "squash" to fit. If you do have other studies, then remove those and see if the issue resolves.
If that does not do it, then you need to look at the underlying data by removing the TPO (or looking at another chart of the bar data) and ensuring that there is nothing wrong with the data that makes up those TPOs.
Finally, if none of this works, then get us a copy of that chart so we can take a look. Follow these instructions:
[2021-08-12 05:46:23]
If there still is an issue we recommend re-downloading the data:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2021-08-13 21:02:54]
Thank you for the reply
Played with the settings and data, nothing
Downloaded the data again today and it worked , no more problem
Have a great weekend
