Date/Time: Tue, 04 Nov 2025 18:08:27 +0000
Non pro CME - Denali - AMP
View Count: 976
| [2021-08-06 11:49:12] |
| eatsleeptrade555 - Posts: 12 |
Hi Support, I would like to use live data from CME group. Are the following steps correct? ( I do not have any live trading account with any brokers) 1) Get service package 11 2) Get Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts 3) Get a live account with AMP (do not need to get cqg nor rithmic from them) 4) Connect it as of this page (Easy Solution to CME Funded Trading Account Requirement) Done? |
| [2021-08-06 14:44:17] |
| John - SC Support - Posts: 42761 |
Yes. That is basically it. To do it fully properly, however, you would do the following (there are a few miscellaneous steps that are covered in these setup instructions to ensure that everything is setup properly): - Follow these instructions to get your account with AMP setup and verified: Easy Solution to CME Funded Trading Account Requirement - Follow these instructions to setup the Denali Exchange Data Feed after you have completed the verification in the above instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-06 17:13:51] |
| Yuri_T - Posts: 21 |
Dear all, I have opened and funded an AMP account, put its number on the AMP verification page, but it does not get verified, says 'Not verified'. What could be the reason for it? Is it because I am on trial and have not subscribed to a service package yet?
| [2021-08-06 18:15:56] |
There seems to always be an issue with this. Please let AMP know about it and have them make sure your account is setup properly to be recognized for this verification.
| [2021-08-10 12:49:48] |
I have gone through the procedure successfully. From what I have understood, the instruction here Easy Solution to CME Funded Trading Account Requirement might be just a little bit imprecise. I will share my experience and SC staff will decide whether they need to update it. When a customer opens an AMP account and funds it, they then should choose 'Sierra Chart-Denali-CQG (No data - Order Routing only)' option when setting up platform/exchange data at this page https://clients.ampfutures.com/live-trading-setup-request. This is an indispensable step, trading platform must be set up to get verified at SC. After that they receive CQG trading platform login and link to set up the password. After that is done, the customer should switch on SC platform go to File/ Data/Trade Service Settings and choose CQG WebAPI and enter their CQG login and password. After successfully logging in (restart of platform might be required) with this option on SC they can go to AMP verification page https://www.sierrachart.com/UserControlPanel.php?page=AMPTradingAccountVerification enter their AMP account number and get verified. After that they can change their Data/Trade Service Settings on SC platform back to whatever they choose. Here is the right procedure, so to say, at least the one I went through. Hope that helps. |
