Date/Time: Tue, 04 Nov 2025 14:58:02 +0000
Is it mandatory to sign forms when on TRIAL ACCOUNT
View Count: 625
|   [2021-07-27 04:04:29]     |
| User579979 - Posts: 12 |
                Hi, Is it mandatory to sign the Uniform Subscriber Agreement & CME Non Professional Certification for a TRIAL ACCOUNT when NOT using REAL TIME DATA using TRADE SIMULATION MODE? Thank you!  |
|   [2021-07-27 13:53:29]     |
| John - SC Support - Posts: 42750 |
                If you received a notification about signing the agreement, then that was in regard to the Delayed Exchange Data Feed. If you are using the Delayed Streaming data for the CME Group, EUREX, or CFE, then we do need for you to sign the agreement for the delayed data feed. You can access the agreement on this page: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements Otherwise, it is no necessary for you to sign. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
