Date/Time: Tue, 04 Nov 2025 14:58:05 +0000
Change tool text size
View Count: 1587
[2021-07-26 12:01:36]
Yeager - Posts: 134
How do I change the text size of say the horizontal ray. The text tab? Or the values of an extended rectangle hi and low? Cant find this anywhere in Graphics settings and fonts. Have gone through them all.
Many thanks
[2021-07-26 12:55:19]
User907968 - Posts: 847
https://www.sierrachart.com/index.php?page=doc/Tools.html#ChangingTheFontSizeForTextDisplayedWithToolDrawings%20
[2021-07-26 17:42:45]
John - SC Support - Posts: 42750
The link given above has an extra space at the end and will not take you to the correct location (note the %20 at the end). Here is the correct link to the specific documentation you need:
Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font)
