Date/Time: Tue, 04 Nov 2025 14:58:09 +0000
different sessions highlight background on chart
View Count: 1192
|   [2021-07-26 08:58:56]     |
| laurence gantier - Posts: 5 |
                hello, I'm french trader please excuse me for my bad english in case of, and try to highlight three session Asian, London and NY with three different color background on the same 15 minutes chart. the first session I specified with Time highlight is working properly but when I try to add a second time range highlight it doesn't work... is the a way to have 3 different background colors on the same chart? thanks in advance for your answer! have a good day Laurence  |
|   [2021-07-26 14:54:05]     |
                You do need to use multiple instances of the Time Range Highlight study. If there is a problem, attach that chart, that has the multiple instances, following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-26 15:16:53
