Date/Time: Tue, 04 Nov 2025 14:58:10 +0000
Chart replay control panel Doesn't open
View Count: 818
|   [2021-07-24 11:57:09]     |
| Galmik - Posts: 42 |
                Hi John this is Mike Hope u r well! I have a problem, two days ago my sierra chart replay was working well but i tried backtesting again today and the control panel window doesn't appear on screen at all. The only way to run backtest is CHART-REPLAY CHART-PLAY/PAUSE that is inconvenient. Any ideas what might be wrong? thank you for your time to answer! Yours Mike  |
|   [2021-07-24 22:22:01]     |
                Refer to: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
