Date/Time: Tue, 04 Nov 2025 14:58:04 +0000
Impossible to have information on current positions
View Count: 623
|   [2021-07-23 14:57:10]     |
| algo221 - Posts: 3 |
                Hello.  I try to access the number of positions but the results always return 0. While there are many positions open on the current symbol. I tried several possible options but the results always return 0. #include "sierrachart.h" SCDLLName(" footprint") ; SCSFExport scsf_footprint(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.AllowMultipleEntriesInSameDirection = 1; sc.AllowOppositeEntryWithOpposingPositionOrOrders = 1; sc.UsesMarketDepthData=1; return; } s_SCPositionData PositionData1; int infopos=sc.GetTradePositionForSymbolAndAccount(PositionData1,sc.Symbol,sc.SelectedTradeAccount); SCString msg; msg.Format("%d",PositionData1.PositionQuantity); sc.AddMessageToLog(msg,0); }  |
|   [2021-07-24 22:12:23]     |
                Are these simulated or non-simulated positions?
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-25 11:07:44]     |
                It's simulation.
|   [2021-07-25 15:20:36]     |
| ForgivingComputers.com - Posts: 1153 |
                PositionQuantity is an integer. Try this: msg.Format("%i",PositionData1.PositionQuantity);
|   [2021-07-26 03:23:10]     |
                Is Trade >> Trade Simulation Mode enabled?
