Date/Time: Tue, 04 Nov 2025 14:58:17 +0000
Live Data
View Count: 527
|   [2021-07-23 01:36:39]     |
| User123179 - Posts: 28 |
                What's the easiest way I can get live data back to my account, I have sent 150 to AMP account, paid for denali feed, but I only gave Ninja account details on CME form, will this be a problem, do I need to get amp to connect account to this platform again. Regards Hayden  |
|   [2021-07-23 05:12:07]     |
                You need to enter your AMP account identifier here: https://www.sierrachart.com/UserControlPanel.php?page=AMPTradingAccountVerification Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-23 05:25:58]     |
| Hayden Glenn Barnes - Posts: 7 |
                Yes have done that
|   [2021-07-23 05:28:23]     |
                Says cleared AMP trading account
|   [2021-07-23 07:42:52]     |
                Reenter it and then click the Update and Verify button and make sure the account number is proceeded with AC. Do not clear it.
|   [2021-07-23 07:48:10]     |
                Still Delayed, disconnected feed then re connected, Account says verified now
|   [2021-07-23 09:02:05]     |
                Restart Sierra Chart.
