Date/Time: Tue, 04 Nov 2025 14:59:38 +0000
Eliminate PP high and PP low in spread sheets
View Count: 533
[2021-07-22 17:58:46]
Bruce - Posts: 50
Good Day i'm using daily Pivot points formula type 0 and would like to eliminate PP hi & PP low from the spreadsheet.. i've used ignore and hidden but SG14 & SG15 still shows up in the spreadsheet. I've haven't used spreadsheet for awhile but I know PP Hi PP low are new since i've last used them.
[2021-07-26 15:26:59]
John - SC Support - Posts: 42750
You need to make sure that the option for Include In Spreadsheet is NOT enabled for each subgraph that you do not want to include in the Spreadsheet. Refer to the following:
Chart Studies: Subgraphs Tab >> Include in Spreadsheet
