Date/Time: Tue, 04 Nov 2025 14:59:31 +0000
Web-Based Trading
View Count: 878
[2021-07-22 16:42:49]
ondafringe - Posts: 328
I used to have this feature enabled, but it is now disabled.
Would you please re-enable it?
And for future reference, is there something I need to do/know about why it was disabled to make sure it doesn't happen again?
Thanks...
[2021-07-22 16:53:17]
SC Support - Posts: 2025
Your Order Routing Service is no longer SC TT(FIX), AMP removed all its clients from that service in February / March, so this Web-based Panel service is not available any more.
If you are speaking about a CQG Web-based trading panel, then that is not something we can help with.
Date Time Of Last Edit: 2021-07-22 16:57:52
[2021-07-22 18:10:28]
Okay, I didn't realize the two were connected.
When you get your CME direct routing going, and I switch to using yours, will I get the web panel back then?
[2021-07-22 18:18:45]
Yes.
