Date/Time: Tue, 04 Nov 2025 14:59:33 +0000
Custom Drawing Tools
View Count: 1515
|   [2021-07-22 04:41:58]     |
| countryboy92 - Posts: 101 |
                I created a custom rectangle tool called TC1. How do I add it to my control bar at the top of the screen in Global Settings. I added a button "CDT1" in custom drawing tools, but when I click on it, it does nothing.
|   [2021-07-22 08:29:44]     |
                You need to add a   Control Bar button for this. Refer to: Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) These buttons are listed under : Tools >> Tool Config # in the Customize Control Bar window. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-22 08:30:00
