Date/Time: Tue, 04 Nov 2025 14:59:31 +0000
automated backtest Alerts Help
View Count: 928
|   [2021-07-21 02:06:45]     |
| adeelchaudhry1 - Posts: 6 |
                Hi, I hope this finds you all well and in good health. I am fairly new to Sierra and have been stuck on trying to figure out backtesting with Alerts. I think my issue is a condition for my alerts, I was wondering if someone can help me with the syntax. Currently, i have " = OR(SG9>0,SG10>0)" " = OR(SG11>0,SG12>0)" Basically, I want it to generate a buy order for SG9 & SG10 ( Arrow Up) and a sell order for when SG 11 & SG12 ( Arrow Down) appear on the chart. When I run the backtest, there are no trades that are being generated.  |
|   [2021-07-21 04:14:16]     |
                You will want to use this study for this: Trading System Based on Alert Condition And you would need two instances of the study. One for a buy entry and one for a sell entry. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-21 15:51:11]     |
                thank you for the prompt reply, i followed the instruction but still no trades popping up. Here is the alerts I used to generate a buy alert in the trading system alert condition section. =OR(ID20:SG9 > 0 , S10 > 0) Both of the signals are in ID#20 Kindly, view the screenshot. You will see the up arrows SG9 and SG10 which are being displayed on the chart, but alerts wont generate any trades. Date Time Of Last Edit: 2021-07-21 15:52:34
|   [2021-07-21 16:30:05]     |
                i got it to work but some trades won't trigger off the alert condition!  its picking some alerts and trading and ignoring others Date Time Of Last Edit: 2021-07-21 17:12:56
|   [2021-07-22 15:04:14]     |
| ForgivingComputers.com - Posts: 1153 |
                How fast are you backtesting? If you are seeing unexpected results, try replaying the trade at speed = 1. If it works at normal speed then you are backtesting too fast.
|   [2021-07-23 02:06:12]     |
                I was backtesting pretty fast, gonna try slowing down, Thanks!
