Date/Time: Tue, 04 Nov 2025 14:59:35 +0000
Can I submit orders on TT(FIX) without a Data Feed?
View Count: 540
|   [2021-07-20 18:21:02]     |
| User155017 - Posts: 41 |
                Thanks Can I submit orders without an active data feed? Can I use another data feed and trade with TT routing using DTC 2 instances of SC and DTC connection?  |
|   [2021-07-22 08:33:28]     |
                Yes there is no data feed required and what would happen by default is delayed data would be received. Can I use another data feed and trade with TT routing using DTC 2 instances of SC and DTC connection?  You can try. Refer to:https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-22 08:34:11
