Date/Time: Tue, 04 Nov 2025 14:59:34 +0000
Dax Futures FDAXU1
View Count: 608
[2021-07-20 07:08:24]
User800098 - Posts: 3
Chart not functioning
[2021-07-20 07:28:32]
Chart still not functioning
[2021-07-20 07:53:55]
Over 40 minutes since reporting and the Chart is still not functioning. Is anybody listening at Sierra.
[2021-07-20 07:54:16]
First thing is to update Sierra Chart to the current version. Instructions:
Refer to:
July 1, 2021: EUREX Realtime Data from Denali Exchange Data Feed Policy
Change your service package to 10:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
