Date/Time: Tue, 04 Nov 2025 14:59:28 +0000
Volume by Price Study
View Count: 783
[2021-07-20 06:06:07]
jjhanna - Posts: 1
Brand new to Sierra Chart (just started my trial) and attempting to create a simple volume by price profile/per day for ESU21. I'm also looking to highlight POC and value area and would like to display a separate profile for the evening session.
The primary issue I'm encountering is all of the horizontal volume bars are displaying as the same length.
Below is a current pic and I've attached the chartbook as well in case that's helpful.
http://www.sierrachart.com/image.php?Image=1626760898815.png
This is obviously a newbie issue and I'd be happy to go through all the doc in the future, just want to ensure I can get this to work before my trial expires - thx so much!
attachmentVol at Price.Cht - Attached On 2021-07-20 05:59:31 UTC - Size: 3.58 KB - 386 views
[2021-07-20 06:44:22]
Sierra_Chart Engineering - Posts: 21301
You must use an Intraday chart for this. Set this setting to Intraday Chart Only:
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method)
Also refer to:
Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts
